Kents RV-10 Construction Site
RV-10
Tailcone
5-19-2008
10-9-3 to 10-10-3
Tailcone Bellcrank Ribs
Fabricated the bellcrank rib angles. Drilled and countersunk the holes for the nutplates. Clecoed the angles to the ribs and final drilled the holes.
Fabricated the 1010B Spacer from the aluminum bar stock.
Pictures: DSC03645 - DSC03646
RV-10 Home
2117
Access Covers and Fl
Aileron
Aileron Actuation
Air Conditioning
112
197
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Control System
Elevators
Empennage Attach
Empennage Fairings
Firewall
Flap System
Flaps
For. Fuse Ribs, BHDS
Fuel Tanks
Fuselage Side Skins
68
149
Horizontal Stab
Horizontal Stabilize
Landing Lights
Mid Fuse Bulkheads
Mid Fuse Ribs & Bott
Outboard Leading Edg
Pitot-Static-AOA
Rear Seat Backs
Rear Spar
Rudder Pedals and Br
Seats and Seat Belts
Stall Warning System
Step Installation
Tailcone
Tailcone Attachment
41
79
Top Wing Skins
Upper Forward Fusela
Vertical Stabilizer
Wing Main Spar
Wing Ribs
Wing Tip
Wiring
