Kents RV-10 Construction Site
Date:  4-12-2015
Number of Hours:  4.00
Manual Reference:  Aileron Trim
Brief Description:  Aileron trim mounting
Mounted the aileron trim to the access hole cover after priming parts. Had to remove the big pushrod from the left wing to mount the attach points for the springs that connect to the aileron trim. Springs seem very stiff, should help center the control stick when it is released.
