Kents RV-10 Construction Site
Date:  9-6-2007
Number of Hours:  1.50
Manual Reference:  7-11-3 to 7-12-1
Brief Description:  Rudder Counterbalance
Got the counterbalance weight match drilled and bent the skins to wrap around it. Once again, this was harder to make this come out right than I thought it would be. In retrospect, I should have put more of a crease in the skin when folding by hand. I made a light crease, and it was difficult to line up the wood block when I went to bend. The bend ended up a little too close to the rib. I fixed this by bending with the counterbalance in place, it came out pretty good in the end.
