Kents RV-10 Construction Site
Date:  4-1-2016
Number of Hours:  3.00
Manual Reference:  29-10-1:29-11-5
Brief Description:  Forward side skins
Twisted the lower and upper fuse channels and got the right side skin bent using the modified clamping block. Even though the skin is smaller than the mid skin this was a harder bend to make. I did end up with a slight kink on the right skin but once it was installed it's not noticeable unless you really look for it.
