Brief Description: Drill Jack screw thrust Bearing
P. 150 says drill letter F (.257) which is an AN4 after drill out drawing FS51 calls out an AN3 bolt. Used AN4 bolt of same length as bearing and frame where matched drilled to letter F.
No vertical play in jack screw and screw turns freely
