Run RG400 from ELT antenna to ELT location. Solder center connector to coax connector
Cubcrafters installs ELT under pilot seat and battery box. ELT is larger than the one that Cubcrafters users and do not want to put in battery box will mount under rear seat.
Run GPS input from ELT location to where panel will be mounted
Run ELT remote head to location to where panel will be mounted..
