Riveted the bottom of the trim tab skin to the trim tab spar and trim tab horn. Aligned the inboard and trailing edges of the trim tab with the trailing edge of the elevator. Match drilled the hinge. Aligned the tab with the elevator. Used a piece of aluminun angle clamped to the trailing edge to get them aligned. Riveted the trim tab and installed the trim tab hinge.
