Stevens Web Site
Date:  4-4-2015
Number of Hours:  7.00
Manual Reference:  Trim Tab
Brief Description:  Prepared the trim tab
To bend the trim tab using the blocks I made, I used double-sided carpet tape I had to keep the parts from slipping on the blocks. It worked very nicely. Bent the tabs using a block of wood and then finished the bend using the flush set on my rivet gun. Drilled the holes of the trim tab skin to the spar. Disassembled the trim tab and machine countersunk the trim tab spar to accept the skin's dimples. Trimmed the trim tab horn for the electric trim servo. Prepared the parts by finsihing the edges, deburring the holes. The clecoed everything back together.
