Finished riveting the hinges inside the leg fairings and cut the pins to length. Fitted them to the legs and installed the hose clamps to secure them. Started putting the propeller together. Used a rubber mallet and my workbench to drive the spacer dowels into the propeller. Temporarilly bolted the prop on while I drill out the holes in the front plate which sits inside the spinner. Sanded the windscreen fairing a bit more. Some slight touch up required in a few spots. but I'm pretty happy with the finish.
