JOHN'S WEB SITE
Date:  12-26-2008
Brief Description:  Install Radios
Cut out hole in dash for radio and transponder. Fabricated a couple of lengths of aluminium to fix the frames to. Ran them a bit higher than needed in cas another radio goes in one day. Marked out and cut hole in the panel behind the dash. Made a bit deeper so I can feed the wiring harness through it.
Angles to hold front of radios
Side view
Side view
Hole behind dash for radio
