I had to go to the Physio in Margaret River today and a couple other things, so not a lot done. I started off deburring the 5/32 holes in the top of the firewall flange. I then rivetted the cold air inlets and fitted the vents and tubing. Getting the nuts on was a challenge. When I came back I started to put in the trim wiring, but quickly discovered that I don't have the wire. Seems to be a common thing nowdays. Anyway I put in the seat belt anchors for the cables that hold the shoulder section. Keeping things in a nice progressive manner, I then decided to put the wheels together. I finally located the parts and have it set out for the morning.
Cold air inlet
Vents (the top left nut was very hard to get to)
Anchors for the shoulder section of the seat belts
