Decided to go back to the canopy for now. Located and drilled the sliding tracks. Cut the front legs on the frame to give the correct height. Took a few goes to get it right on 3/8". I then tried to get the frame to match the fuselage. I saw on others web pages that they got a bit frustrated with this. I understand why. Everything else in these kits fits so well. This thing is not quite right, but extremely difficult to bend to the right shape. Got it pretty close for now. Will make some more adjustments later if necessary. Could spend hours and hours on this. Located and drilled the sliding track which fits on the the centre of the aft top skin.
