Riveted in the stiffener behind the baggage bulkhead. Also drilled and fitted the side air vents to the fuselage skin. Sealed them and will rivet when sealant is dry. Decided to start on the canopy as I want to finish some stuff off under the forward deck and the gear from Vans is not far away. Made up rollers, roller tracks and started top slider guide.
