Made up a stand to set up the fuselage at a more comfortable height. Riveted the skins up to the longerons then levelled the centre section. Fit the aft deck and pulled the fuselage across till it too was level. Clamped, drilled and clecoed the deck to the longerons. Fabricated a couple of spacers which go under the deck. Made up and fitted the forward gussets, then drilled them to the longerons. Ordered some more super etch primer and thinners for the Anzapon, which I will still use in the aft section. And yes I had a sit in the cabin today.
