Brief Description: Fitting control surfaces to wing
Fitted all parts to airleron bellcranks and made up the push rods. Set up first wing on table and fitted airlerons using jig to find and hold neutral position. Fitted flaps and drilled holes in piano hinge. Trailing edge looks great. Finished off, removed airleron and flap and replaced wing in the frame. Went to Busselton for a flying lesson in the afternoon.
