Installed outer tank ribs, Fuel Capacitive Sender Units, fuel pick up tube and rear baffle. Tank is fulled sealed apart from inspection cover which I will leave till later. Increadible amount of work in this, it has surprised me how much, but at last one is finished. Will install tomorrow when it has cured a bit overnight.
Started back on outboard leading edge, rivetting out most rib. Will start on others tomorrow.
