Started at the tail section and worked forward doing bits and pieces. Put the nuts on the bolts on the rudder. Not a 5 minute job. Tried bleeding the brakes, but can't seem to get all the air out. Will try later. Riveted the wing tips on then pulled out the wing light kit. Cleaned up the parts and primed them. Will paint matt black for now. Put the cowl back on and the 2 rubber seals that fit on the bottom cowl intake.
