Sanded back the glass on the farings then mixed up some glass micro balloons and filled the edges of the farings where they meet the wheel pants. Also put some on the rear windscreen faring. Soldered a coax fitting onto the transponder and fed it through the wing bulkhead. Made up 2 new strips which tie the rudder cables to the pedals out of some heavier material. Made up a stiffener fro the VHF antenna which I am mounting under the passengers side floor.
Had a visit this morning from Preston Boley, an RV owner from nearby.
