Spent ages trying to work out the wiring, but finally got my head around it. The harness looks like it has a female fitting where a male should be. I will need to pull up the floor panels to run the antenna for the VHF and transponder. Also discovered the harness is too short to reach where I put the Intercomm switch. Moved to beneath the radio stack. Secured the radio frames to the dash.
