Fitted the bracket to the bottom of the cowl exhaust outlet. Worked on the cowl hinges a bit. Repositioned and secured exhaust pipes. Relocated fuel line away from exhaust. Cut and fitted the scat tubes for cabin heat. Secured the wiring in the centre tunnel.
