Finished off making and fitting the filtered airbox. Fitted the Carb Heat Muff. Clecoed the cowls on, drilled the bottom hinges and filled the gap the the forward top skin with epoxy. Ran another wire to the tail for the aft nav light and then tidied up and secured the wiring throgh the rear of the fuselage.
