Continued fitting the engine baffles. Started fitting and riveting the rubber airseals to the top of the baffles. Fitted the oil cooler. The bolts are too long so you have to make a couple of packers. Connected the oil lines and had to make a few adjustments to get clearance. Clearance is starting to become a slight problem now.
