Fabricated the bottom HS fairing, but need a tap to thread the screws before I can complete. The top empenage fairing doesn't fit all that well. have drilled and clecoed in place and tried some heat to get it to bend down. Moved a bit, will do some more later. Cut the elevator and HS tips and epoxied the aluminium strips inside wherethe pop rivets will go. Also made up a couple of bits of fom to go in the HS tips to hold the fibreglass cap.
Lastly I cut and shaped the bottom rudder fairing. Stll a bit to go, but getting there.
