Not sure whatr happened to today, just went. Finally got some progress with Superior Air Parts. Will make the payment tommorow and it will be shipped top Perth straight away.
Realised I stuffed up the WH 800 terminal block so bought some cutting board material and made up some new ones. Still not happy with it so will buy another set from Vans. Finished installing the Main and starter relays. Drilled the circuit breaker holes and ignition swith hole in the instrument panel. Made up the brackets for the strobe power box. I am going to fit this to the floor behind the baggage compartment wall. Did a couple of other bits and pieces including the forward elevator push rod. Tight squeeze, but I got it in there. Everything seems a bit fiddly and time consuming at the moment. Made a couple of silly mistakes over the last few days requiring reordering gear or rework. Need to spend a bit more time on the drawings I think. No picks today as not much to show.
