I used phenolic electrical wire cable stand-offs to make rollers for rudder cable to bend up after the bushings. I did not like how the cables would wear on the plastic bushings. Not sure if I will keep this idea because there are castle nuts with cotter pins that I will not be able to access with the baggage floors installed.
