Daytons Web site
Date:  11-6-2004
Number of Hours:  20.00
Manual Reference:  Sec 8
Brief Description:  Wiring
Section 8 Fuselage Date 11/6/2004 At this point in the construction I decided to install the wiring in the fuselage. I started with the battery location and hold down bracket. I installed the master relay and the starter relay. From there I install all the other electrical components and wire. (Image) 260,261&262 (Image) 264,265&266 (Image) 254,255&258
Master relay is below
Starter relay
Starter relay
Battery bracket is made from .060 aluminum
