Date 4-16-06 Sec 12I started the FAB 320 filter air box today. I trimmed the top plate to allow the cowl to fit. Next I installed the air filter and cut the filter to fit over the accelerator pump housing. After adding RTV to the filter I bolted the air filter and plates together I installed the cowl and adjust the top plate to meet the air inlet both vertically and horizontally. I used fluting pliers to adjust the flange of the top plate to meet the inlet in the cowl. After this I removed the assembly from the aircraft and installed the airbox .I trimmed the airbox to length and slit the sides at the bend point in the airbox plate. After adjusting to match the inlet size of the cowl I trimmed a pie shape from the sides of the airbox. I rough up the exterior and lay 3 layers of 9oz glass and epoxy resin over the cut area.(Image) 00-0357,00-358 &00-360
