Daytons Web site
Date:  4-3-2006
Number of Hours:  3.00
Manual Reference:  Sec 6
Brief Description:  Re-Build Left Elevator
Section 6 Re-Building left elevator Date 4/3/06The last operation is to assemble the skin to the frame. I back riveted the servo back plate to the skin, Fit and drill the trim tab hinge. Clecoed the skin to the frame and then clamped the assembly to the top of my workbench to keep it flat and without twist. I squeezed as many rivets as possible while checking the aft edge for twist. Repeated the same process on the upper surface and installed the trim tab hinge. The end fairing was predrilled and easy to install. I rolled the leading edges and pop-rivet them together.(no images available)
