Mitch Hodges (N601MH)
Date:  7-4-2005
Manual Reference:  6SV-0-LE
Brief Description:  Drill Hole and Attach Sender
Set flycutter and drill trial hole in wood for size. Test on scrap AL to insure size, and test fitting sender in tank. Mark hole center position on tank. Drill a #30 pilot hole in tank. Use brace and flycutter, cut hole in tank. Debur hole in tank Blow out all scrapes and filings. Insert sender into tank. Take photos
Brace with Flycutter, Hole Drilled
Sender, Bent and Ready
Sender Attached.
Sender Attached.
