Mitch Hodges (N601MH)
Date:  4-8-2005
Number of Hours:  1.00
Manual Reference:  V-14 Step 22
Brief Description:  Practice cuts to trim LE skin
Made some practice cuts on scrape to determine best method to cut LE skin. Cleanest method was with a laminate trim bit in a router, but could also cause problems. "Safest" is the manual method, but will produce least straight cut, and may take longest to clean up. Marked LE skin for pilot holes along spar.
