Called Zenith factory and discussed options with Roger to handle LE/Spar holes being under 10mm specs. He said that it should not be an issue, but should be an inspection item to watch during annual. Also recommended adding a rib cap extension rather than cutting skin to handle misplaced rivet holes.
