Mitch Hodges (N601MH)
Zodiac 601HDS
6SV-0-LE
Test fit the tank
Test fit tank onto bottom of skin. Had to file the fuel drain outlet hole in skin slightly to make a fit. Used Dremel with grind stone to slightly oblong the hole for a fit.
With a slight adjustment, tank fits!
Drain outlet as seen from bottom.
Tank Vent as seen from bottom
Zodiac 601HDS Home
160
Ailerons
135
