Mitch Hodges (N601MH)
Zodiac 601HDS
6SV-0-LE
Make Template for fuel outlet
Using scrap AL, make a template showing the location of the fuel outlet in relationship to the back and bottom of the tank, on the spar side. This will be used later to drill the hole for the fuel outlet through rib NR7A, per plans.
Zodiac 601HDS Home
160
Ailerons
135
