Brief Description: Drill Ribs for Screws to Secure Duckworks Kit
The Duckworks kit came with another paper template that Heather cut out and glued to a piece of cardboard. Once the template was in place on the outboard rib, I drilled through the holes in the cardboard template and through the rib. The template was then moved to the next inboard rib and used to drill those 2 holes as well.
Duckworks template positioned on outboard rib - Holes drilled
Duckworks template positioned on inboard rib - Holes drilled
