1. Prepped and primed servo mounting bracket parts and lower side skin stiffener. Cleco'd lower side stiffener in place.
2. Mounted servo bracket in place using CCPQ-43 rivets, and AN3 hardware.
3. Performed test fit of push-pull rod and found that it was about 1/4" too long. Shortened push-pull rod and re-tapped internal threads.
4. Prepped, primed and painted push-pull rod. Threaded into place on previously-installed inboard bearing. Attached outboard bearing using AN3 hardware, including an oversized washer as protection against bearing failure.
Expect that push-pull rod will require additional adjustment during aileron rigging process.
