Tom's Rans S-19 Builders Log
S-19
Flaps
6-27-2010
Fitting of LH flap skin (2)
Drilled LH flap skin to #30. Noted that leading edge of skin not conforming to rib shape as well as one might expect. Will check clearance on wing once wing skin is attached.
Removed clecos and put assembly aside for now.
Root end - the leading edge may need more work
Outboard end
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
