Tom's Rans S-19 Builders Log
S-19
Ailerons
6-5-2010
Initial Assembly of LH Aileron Frame
Performed inital assembly of the LH aileron frame per the Rans manuals. Details as follows:
1. Assembled ribs to center aileron stations on aileron spar using 3/32 cleco's.
2. Cleco'd hinge halves in place - these were fabricated and drilled to 3/32 during LH wing frame assembly.
3. Separated sections of the spar reinforcment plate (KPAL0072) using a dremet tool, then polished the edges on the scotchbrite wheel.
4. Fabricated the .025 shim per Figure 04A-05.
5. Assembled parts to the outboard rib station to the spar, drilling as required to 3/32 and cleco'd in place.
6. Assembled parts to inboard rib station to the spar, drilling as required to 3/32 and cleco'd in place.
7. Drilled all rivet holes to 1/8, with the exception of the nut plate attach holes.
The LH aileron frame is ready for disassembly, deburring, edge polishing, and priming.
LH Aileron - Outboard End
LH Aileron - Inboard End
Ready for the next step
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
