Brief Description: RH wing rear spar and frame assembly
Completed assembly of the RH wing rear spar and frame per the Rans manuals as follows:
1. Cleco'd rear spar and reinforcemtns to wing ribs and drilled remaining holes to #40. Transfer drilled all holes to #30, then the three bolt holes to #11. Removed the thick reinforcement plate and enlarged one hole to #1.
2. Deburred all holes, touched up primer on ribs. Primed spar reinforcements and areas on rear spar to be be riveted.
3. Riveted rear spar and associated components to the wing frame per the Rans rivet schedule.
