Tom's Rans S-19 Builders Log
S-19
Fitting of top cowl
Fitted top cowl per Rans video and manual as follows:
1. Rough cut the prop flange and cylinder openings on top cowl.
2. Performed initial seam cut behind spnner back plate and just aft of cylinder opening.
3. Drilled fastener holes for inboard fasteners on cylinder openings to #40, then to #30.
4. Made rough cut on aft edge of top cowl to expose firewall rivets.
5. Measured final cut from 3" reference line and made final cut. Filed and sanded edge smooth.
6. Made rough cut on bottom edge of top cowl for seam with bottom cowl.
7. Measured final cut from 1" reference line and made final cut. Filed and sanded edge smooth.
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
