Tom's Rans S-19 Builders Log
S-19
Performed leak check on fuselage fuel system
Peformed leak check on fuselage fuel system as follows:
1. Removed hoses and fittings from gascolator. Conneced low pressure regulator to one opening and plugged the remaining opening.
2. Capped LH wing fitting and placed fuel selector to "LEFT" position.
3. Applied 5 psi of air pressure to gascolator.
4. Checked fittings for leaks using soapy water. Appliied LocTite 567 sealer to threads of leaky fittings and retightened.
5. Repeated process on RH side.
6. Removed test rig and replaced gascolator hoses.
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
