Tom's Rans S-19 Builders Log
S-19
Rotax ignition wiring
Wired Rotax ignition connections in accordance with the Rotax installation manual as follows:
1. Identified and disconnected ignition module connectons associated with mag switch connectoins.
2. Crimped male connector pins and weather seals on mag switch wiring and inserted pins into the connectors.
3. Re-connected ignition module connectors.
4. Identified and disconnected ignition module connectons associated with the "easy start" feature.
5. Crimped female connector pins and weather seals on easy start wire (from starter solenoid) and inserted pins into the connectors.
6. Reconnected ignition module connectors.
7. Grounded shield of mag switch wiring to ignition module mount.
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
