Tom's Rans S-19 Builders Log
S-19
Performed pitch bungee modification
Installed pitch bungee modification as follows:
1. Removed flap mechanism bracket and drilled for 3# eyebolt. Installed eyebolt, washers and nut. Reinstalled flap mechanism bracket.
2. Marked forward push-pull tube and installed metal tang and hose clamps.
3. Installed bungee and closed hooks iwth vice grip pliers.
4. Tested bungee testing for 8 lb pull resistance at the vertical stick positioin.
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
