Tom's Rans S-19 Builders Log
S-19
Joining Forward & Center Fuselage 1
Begain joining the forward and center fuselage sections as follows:
1. Cleco'd bottom skin on forward fuselage. Enlarged center rib holes to #30.
2. Poisitioned forward section in place and cleco'd floor ribs to center spar.
3. Attached longerons to the center section with cleco's.
4. Fabricated two fixtures from aluminum angle to position firewall parallel to center spar, cleco'd and clamped in place.
5. Checked assemblies to be level and square with each other. Drilled longeron into steel firewall weldments and cleco'd in place.
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
