Tom's Rans S-19 Builders Log
S-19
Forward fuselage floorboard assembly
Assembled forward fuselage floorboard as follows:
1. Prepped and primed floor ribs, channels, inspection plate, and bottom of floorboard skin.
2. Riveted floorboard frame together.
3. Riveted floorboard skin in place on frame, using sand bags to hold things straight.
4. Mounted brake cylinder mount brackets using #8 hardware
5. Mounted nutplates on floorboard and attached floorboard inspection panel with #8 stainless machine screws.
6. Attached brake cylinders to mount brackets per Rans parts manual.
7. Temporarily ounted rudder pedal bearing blocks in preparation for fitting of rudder pedals.
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
