Tom's Rans S-19 Builders Log
S-19
RH wing - fitting of upper aft skin
Fitted the upper aft skin, wing walk skin, tip skin, and spar extension to the RH wing as follows:
1. Flipped wing assembly over exposing the upper frame. Marked centerlines on all ribs.
2. Placed upper aft skin and wing walk skin on the frame and cleco'd to aft spar.
3. Checked alignment of ribs through pre-drilled holes in skin. Drilled to #40, starting from the center working outward.
4. Fitted upper tip skin and cleco'd in place. Fitted spar extension in place and drilled remaining holes, cleco'd in place.
5. Fitted inspection hole ring in fuel sender opening and cleco'd in place.
6. Drilled all holes to #30.
Drilled to #40
Drilled to #30
Upper tip skin and spar extension
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
