Tom's Rans S-19 Builders Log
S-19
LH wing final assembly - wing tip (1 of 2)
Began assembly of LH wing tip as follows:
1. Fitted the wing tip skins, cleco'd in place and riveted per Rans manual rivet schedule.
2. Fitted the landing light lens in the forward section of the wing tip. Riveted in place using AVEX rivets and aluminum washers.
3. Riveted landing light assembly in place using AVEX rivets.
4. Completed initial fitting and drilling of wing tip fairings. Farings are cleco'd in place using 3/32" cleco's.
All that is left is to remove the tip farings for final trimming, adding the wing tip stiffener strips, drilling to #30, and riveting in place.
Wing tip skins in place
Landing light installed
Initial fitting of tip fairing
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
