Tom's Rans S-19 Builders Log
S-19
Completed drilling of RH aileron frame
Fitted frame parts and drilled RH aileron per Rans manuals:
1. Drilled all parts as required to #40 and attached with cleco's.
2. Enlarged all rivet holes to #30, except for the four nut plate mounting holes.
3. Enlarged mounting holes for the aileron horn angle to 3/16. Will enlarge control rod hole to 3/16 once the frame is riveted together.
4. Marked all rib stations and disassembled the frame parts in preparation for deburring,edge polisihing, buffing, and priming.
Outboard end
Inboard end
Ready for disassembly
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
