Tom's Rans S-19 Builders Log
Date:  1-16-2009
Number of Hours:  1.50
Brief Description:  Setting angle of Rib #7
The Rans instructions direct installation of all forward VS spar components prior to
setting the 71 degree angle between Rib #7 and the forward spar. I found it easier to
remove all but the VS Plate and Rib #7 from the front spar. This removed the
unnecessary components while setting the 71 degree angle for Rib #7 and allowed
the spar to laid flat on the work table. Fewer parts to deal with made setting the angle
much simpler, and I was able to use the work table as a reference. I then clamped the
two VS Rib Stiffeners to the rib and spar. Since some of the clecos needed to be
installed on the rear of the front spar, I found it easier to overhang the work table and
place the rib facing up to set the 71 degree angle. Due to this technique, I had to use
109 degrees. I then drilled the required holes in the #7 Rib, VS Plate, and Front Spar
in #40 holes, replacing clamps with clecos and rechecking the 109 degree angle as I
drilled. The rest of the components to the front spar were reattached and are now
ready for transfer drilling to #30 before continuing with the remainder of the steps.
Rib Stiffeners in place, #7 Rib set to 71 degrees
Sighting the #7 Rib angle against the protractor set to 109 degrees
All of the VS Front Spar back together and ready for transfer drilling to #30
