N2C...CruZer
Date:  6-9-2017
Number of Hours:  2.50
Brief Description:  Cabin Floor...Rudder Pedals
So started assembling the cabin floor...no mystery, lots of parts.
Temp mounting of rudder reveals a difference in height from the floor, between the middle plastic bearing to the end bracket of about 1/8"...don't like that. Also don't like that the end bracket is metal on metal.
There should never be metal on metal wear in a rotating situation like this...so easy to add a bushing which can be replaced as it wears.
I ordered a couple of Bushings from McMaster Carr...7/8" OD and 3/4" ID. I'm going to make two new brackets to accomodate the bushings....either that or I'd have to add a 1/8" washer/spacer underneath the existing bracket. Adding a bushing will be relatively easy...so I measured and am ready to make two new brackets on some 1x2 aluminum stock I had. The flange of the bushing is 1 1/8" which actually works perfectly with the height from the cabin floor required. Need to get those bushings to complete.
Will move on to the brake cylinders.
Cabin Floor
Cabin Floor
Height Difference
Height Difference
Getting ready for 7/8
Getting ready for 7/8" OD holes for 3/4" bushings
