Installed the vertical flaperon control arms, there are two spacers that go on either side of the bearing. My question is I believe there should be a penny washer larger than the bearing next to the bolt to prevent the bearing race from ever slipping out....the only problem is it appears that would limit the range of motion required...as that's what the spacers are there for...need to confirm this.
